TwinTurbo.NET: Nissan 300ZX forum - How is a heat soaked manifold a con to a MAP sensor?
sfarrah
on January 29, 2007 at 8:24 PM
Re: So, pretty much...
posted by pionkej
on January 29, 2007 at 08:10 PM
With a MAP based system you use an Intake Air Temp sensor. How does a MAF help any when the intake air changes temp downstream of the MAF?
MAF vs. MAP
pionkej
19:36:20 01/29/07
So, pretty much...
WAGGZ
19:52:15 01/29/07
pionkej
20:10:23 01/29/07
How is a heat soaked manifold a con to a MAP sensor? -
sfarrah
20:24:44 01/29/07
Re: How is a heat soaked manifold a con to a MAP sensor?
pionkej
20:52:30 01/29/07
How does an intake air temp sensor get heat soaked?
dogpile
21:50:51 01/29/07
ztunerz
12:07:23 01/30/07
MAF sensor measures correctly
AntiHero
21:32:26 01/29/07
Re: MAF sensor measures correctly
pionkej
22:10:50 01/29/07
well you cant argue with "actually, no" (n/m)
AntiHero
23:48:05 01/29/07
The VPC is an outdated obsolete device from HKS.
AzHeat
11:40:39 01/30/07
The AEM offers finer resolution and a lot more control than
ztunerz
11:53:53 01/30/07
correction on vpc >>
ztunerz
11:48:16 01/30/07
Sounds like Clark was giving you an Infomercial on
AzHeat
13:25:01 01/30/07
JWT ECU vs AEM comparison @ >500 whp - Cost analysis
ztunerz
13:55:26 01/30/07
Re: JWT ECU vs AEM comparison @ >500 whp - Cost analysis
pionkej
15:06:55 01/30/07
The AEM has user control over all parameters, the
AzHeat
15:27:38 01/30/07
no you are wrong >>
ztunerz
22:20:57 01/30/07
You talk to Clark for one hour and now you become an
AzHeat
23:47:00 01/29/07
I never said I was an expert!!!
pionkej
07:59:08 01/30/07
yea Okay
AzHeat
08:38:06 01/30/07
LEARN TO READ AzHeat.....then STFU!!!
pionkej
09:52:52 01/30/07
LOL (n/m)
AzHeat
10:01:15 01/30/07
Re: LOL
pionkej
10:03:39 01/30/07
I think you need to learn to read and write from
AzHeat
11:21:49 01/30/07
You sounded like Borat with your last sentence (n/m)
ZiNnYc
12:15:49 01/30/07
Honda uses Map so does GM and Mazda - can't be that bad (n/m)
ztunerz
13:58:20 01/30/07
Great analogy.
Ash's Z
13:48:17 01/30/07
much better >>>
ztunerz
14:03:17 01/30/07
I will try and keep it in order this time AzHeat
pionkej
14:34:33 01/30/07
You are just making excuses for you lack of writing skills.
AzHeat
15:07:26 01/30/07
stop putting words in my mouth
pionkej
15:28:27 01/30/07
Did you get Clark's autograph too while you
AzHeat
15:46:33 01/30/07
